The whole point of calibrating or needing a calibrated analogue meter is debatable, certainly beyond a known set point that aligns perfectly with a division mark on the scale as one persons judgement on a portion of a section between two such divisions is subjective. On the other hand, digital meter that particular error is thus removed, even a cheap arse meter will read on a low scale to at least a 1/100th of a division. With 4,5,6,7,and 8 digit meters are even worse, there is no such subjectiveness, it is what it reads and if it reads 95uV then you really want to know that it is 95uV and not 95mV for example.
I'm not aware of any analogue multimeter that claims to have an accuracy anywhere near that of say 4 digit reasonable multimeter, even with an anti parallax mirror the closest I think you can get would be .1 of volt.
So yes, it was possible to calibrate analogue meters and indeed was a requirement to check other meters against to ensure that 15v was the as 15v on another meter surely but digital meters have moved the game on to far more significant digits and different calibration standards surely???
