Good evening,
I'm currently trying to fix my monitor and have had limited success. It's gone from constantly flashing to only a few times coming from standby. I'm in the process of replacing the caps on both the power supply and the io board ( not sure what to call it) and noticed a few that I believe are actually inductors but I seem to have a hard time identifying them or their values.
They're in what appears to be a blue plastic container with a sticker that says "73G259-901-BX-1420". I believe their inductors due to the stencilling on the board - ex L6030 <- I'm assuming that the L stands for inductor.
Would someone be willing to help understand how to identify these? Everything I've seen online states that there should be 3 numbers and possibly a letter but if that's the case then why did they bother including the 73... BX-... 14... in there?
Sorry if this is an obvious question. It's just tired of having to disassemble my monitors so much... I have 3 and they all decided to start having issues at the 10+ year mark.
Thank you for all your help :-)
