Author Topic: Identifying a connector  (Read 1710 times)
Offline MikeyTopic starter
  • Just hit 3rd!
    • captain-slow.dk
« on: June 18, 2019, 04:46:47 pm »
I just started a project, where I will make a new controller for my air condition.
The simplest way I found to do this, was to just disconnect the existing controller, and keep all the high voltage control as it was.
To control fans and compressor, I got a 5 pin connector with gnd, 5v, fan high, fan low, and compressor.
I tried to google 5pin connector, and also tried with locking connector. I tried to find it on digikey too, where I am pretty sure it will actually be, but I think it is drowning in all the results.
Does anyone know what type connector this is?
captain-slow.dk | 3D printing | CNC machining | Mechanical designs | Simple electronics
Offline mikeybarber
Re: Identifying a connector
« Reply #1 on: June 18, 2019, 05:05:28 pm »
Things that might help:
1) Measure the pitch as exactly as you can.  Have a micrometer?
2) Zoom in on any special markings on the housing.
The following users thanked this post: Mikey
Offline Domagoj T
  • Country: hr
« Reply #2 on: June 18, 2019, 05:08:03 pm »
  • Just hit 3rd!
    • captain-slow.dk
« Reply #3 on: June 18, 2019, 05:20:58 pm »
Taking a closer look helped!
The markings says FAF and after a google search this picture turned up https://sc02.alicdn.com/kf/HTB16oMRc6fguuRjSspkq6xchpXax/High-quality-electric-male-female-connectors-pin.jpg
https://www.alibaba.com/product-detail/High-quality-electric-male-female-connectors_60790858384.html
That is exactly the connector already on there. The pitch is 2.5mm, so it is pretty standard.
A bit further digging lead me to this https://www.ebay.co.uk/itm/2-3-4-5Pin-JST-SM-Plug-Male-Female-Quick-Wire-Connector-Adapter-Terminal-Easy/183834756209 and that is where I also saw the connectors before! It seems to be exactly the same used for many LED strips. I knew I had seen them before, and it was driving me insane I could not put a finger to where I had seen them.
