I've had a Hakko FX888D for a year now and I've essentially been using just the included chisel tip (T18-D16 1.6mm chisel tip) which has worked well for much what I've needed to solder, but for soldering 26awg+ wires to fairly small connectors can be problematic, so I'm in the market for a finer tip soldering tip.
Is there anything out there that folks might consider a "general purpose" fine tip for the FX888D? I'm planning to do precision SMD work with it, mostly soldering thin wires to connectors (i.e.: micro usb) where the chisel tip may be a little bigger than than the pad to be soldered to. I don't do enough soldering to warrant purchasing the perfect tip for every job, but I'd like to have something a little smaller as another option when trying to fix stuff. Hope you understand, any suggestions are greatly appreciated. Thanks.
