Hi
I have a wemos D1 mini pro that I want to power with a 3.7v LiPo battery and a TP4056 module.
I have a 91k and a 750k resistor acting as voltage dividers on the output of the module to reduce the voltage from 3.7v to 3.3v.
Measuring the output of the divider directly does give 3.35v as expected. However if I connect the D1 mini to it, all I get is 0.6v and the wemos does not power on.
Nothing gets hot and the charging module shows the battery as fully charged. The D1 mini works fine with USB power.
Here is a schematic of the D1 mini:
https://wiki.wemos.cc/_media/products:d1:sch_d1_mini_pro_v1.1.0.pdfI have the voltage divider output connected to the 3.3v and GND pin. There is no diode, so it should work.
I have the TP4056 module's input connected to the 5v pin of the D1 mini. This lets me charge the battery when the D1 is plugged in and works fine. I have tried disconnecting it though to make sure that was not the issue but I still get 0.6v.
Anyone have any ideas?
Thanks in advance.
