I have no idea why they show red, blue, blue on the top row. They're all scalable to any size.
The rest are mostly a matter of economy-of-scale. You don't want to bother with all the hardware required of an LLC or full bridge topology. Although, as integration becomes more common, these are more economical at smaller scales (see Power Integrations' stuff for example).
As power and especially current goes up, it becomes much more desirable to use multiple phases in parallel. This significantly reduces input and output ripple current, and proportionally reduces the peak switching current, which helps with parasitics and snubbing, or in the extreme, makes the whole thing possible at all (where parasitics are too great, relative to the voltage, current and switching speed).
