shawn01, I don't know where "around here" is but here in the USA in order to work on avionics most shops require a FCC General Radiotelephone Operator license plus a A&P (Airframe & Power Plant) license. The FCC license is required to work on radio transmitters and the A&P license is required because much of the avionics interface with the flight systems (fly-by-wire) etc.Now in answer to VladKEasternTigers question. I googled "avionics" and the first 2 results were "Avionics Magazine" at http://www.aviationtoday.com/av/ and "Avionics - Wikipedia" at http://en.wikipedia.org/wiki/Avionics. These are a couple of good places to start. Good luck.
Also try 'Avionics', this is what describes aviation electronics.
