Thanks for the replies.
Yes she tried water and gel but no foaming, the unit charges to green light status.
It's this one :
https://www.emmi-pet.com/p/emmi-pet-basic-set/0043
She emailed tech support so waiting for an answer from them, but she's in RF where tech support isn't so reliable :/
Okay, that thing is ultrasonic and not only sonic.
Anyhow, I think it will be difficult for someone who has never used a scope before to test this thing electronically. I´m quite sure that the ultrasonic generator uses some kind of resonant circuit to reach the MHz-oscillation frequency. That means you can not test the handle with the driver for itself, you probably need to test everything in an assembled state.
There would be more than one possibility to electronically detect the oscillation. But for a normal consumer it will be much easier to check the efficiency more directly.
Tell her to dive the brush head into sparkling water and then switch it on! I´m serious, ultrasonic waves are often used to degas liquids, if the generator is working you should clearly see the water bubbling up as soon as the ultrasonic generator is activated. If it can't significantly degas sparkling water, then it also won't be able to remove dirt.
