Hey guys, I know very little about electronics, just the bare basics with semi-decent soldering skills.
I am building a guitar pickup winder. To be cheap and easy I could buy this
5 digit display with sensor
https://www.ebay.com/itm/223331093919It's battery powered for the display but works and reads 1200rpms. The motor I will be using is a 12v 1200rpm, and I need 5-digits because pickups are around 18000 windings.
I would however like a powered display
https://www.ebay.co.uk/itm/293493654999Looks like rpms are fine, 5-digits, etc... Where I got lost was the sensor. NPN, PNP, closed, open, 2wire, 3wire....plus the digital display has no reset, which I assume is simply a momentary switch attached?
Hoping to get some advice... Again, no biggie to use the battery lcd, it's already done and ready to go, just rather the led display because easier to read. Looking to run off a 12v power supply... Has 2 motors, 1200rpm and 10rpm, both 12v. Will connect a motor controller to each for speed and reverse. Thanks.
