I have a Pioneer 4200nex aftermarket radio and I get this weird clicking noise coming from the front and rear tweeters only. I do have a good ground and its connected to a bolt that goes into the tube running through the dash. The noise doesn't play when the car is in ACC. It does play when the car is in the "On" position but no engine and with the engine on I get the same noise. Doesn't matter if the volume is up or down it just stays the same. The noise is present on all inputs radio, Apple carplay, xm radio and aux. I tried leaving the antenna unplugged but still no. So that makes me think one of the car computers is sending it RF radiation somehow through the wires. So I installed Ferrite beads on the Yellow, red ACC and orange illumination wire power wires. This did nothing so I installed them on the RCA cables and still nothing. I really don't want to use a ground loop isolator. I heard they reduce sound quality and are just a band-aid. I want to fix the problem from the source. I have tried another radio (JVC KW-V820BT) and it made the same noise. I'm about ready to give up but it might be my amplifier? Any help would be greatly appreciated!
Also, when I turn on my lights (doesn't matter if its the parking lights or low beams) I get a high pitch but not that noticeable noise.
My car is a 2008 Nissan Altima with factory Bose amplifier. I'm using the Metra 70-7553 to convert the receivers pre-outs to the factory amp. I feel like this is the problem. The noise goes away if I unplug the pre-outs. Let me know and I can make a video of the noise. It sounds like a ground loop and makes a ticking noise every 2 seconds and stays the same even at different RPM levels.
Edit: I looked at the service manual and it says on page 159 that pin 10 is for a shield. Should I connect that to the radio chassis? I believe it might be for the RCA cables.
https://drive.google.com/file/d/1uqSI5oc7c_czuu2mk_Bb8wxv5SCc6nvm/view?usp=sharing
