Thank you for your responses. I'm back with one more question.
I have attached a piece of schematic for the LVDS connector. I want to minimize the number of wires in it (that I am intending to extend). As you can see the connector has 28 pins; well it has 30, two for the GND legs (or whatever they are called in connectors) that get soldered to the motherboard. I guess I can ignore those two.
I have opened up the cable and it actually only has 24 thin wires as there are no wires for pin 5, 15, 18 and 21 (even though schematic shows that pin 15, 18 and 21 are GND).
So that leaves pins 1, 11 and 12. Can I reduce them to just one wire? or it affects signal integrity?
If I can reduce them, what would be the best configuration with least number of wires? I have attached two configs that came to my mind. Are any of them possible? If so, that'll reduce the thin wires that I have to run from 24 wires to 21 wires (which is great).
I'd love to hear your opinion. Again, I have not studied electronics, so sorry if it's stupid question.
P.S. Even if I can just replace wire 11 and 12 with just one wire, it'd be good. But please let me know the best config possible. Thank you!
