Author Topic: How to make this Footprint for AD  (Read 204 times)
Offline mengfeiTopic starter
  • Country: ph
« on: June 28, 2024, 03:40:36 am »
i have scour the net for info but it's seems i cant get no satisfaction from where i am  :scared:
https://source.z2data.com/2020/4/7/2/20/36/767/3554352/TP102.pdf
i'm not sure how this Macom RF Pulse Transformer is installed on a PCB.
thanks for the ideas.
& this one too, thanks
https://www.st.com/resource/en/product_presentation/new-molded-module-for-industrial-power-applications.pdf
SB49W65M5AG
« Last Edit: June 28, 2024, 03:43:33 am by mengfei »
Offline xvr
  • Country: ie
    • LinkedIn
Re: How to make this Footprint for AD
« Reply #1 on: June 28, 2024, 11:00:36 am »
You should manually bend its pins before soldering to PCB. https://matr.com/lead-forming/
Offline Doctorandus_P
« Reply #2 on: June 28, 2024, 01:29:28 pm »
I see a few options here. Most common is lead forming as xvr already mentioned (either in THT or SMT form). The other option is to route a hole in the PCB and put the thing in the hole.
