Hello people of EEVblog, this is my first post and I'm happy to join this community.
Here's the story: I acquired a Security cam Video recording setup which includes a "H.264 Network DVR". It was in full working condition...until of course I dismantled it.
Check Attachment 1
When it was functional, the network DVR could accept input from 4 video sources, 1 audio source, 3 USB inputs(One for mouse), something called RS485, a VGA output and an Ethernet port.
Check Attachment 2
Inside I found a 500 gb hard disk, a video processing board and an 8 bit board for the front panel controls.
I tried super hard for half a day to identify what this board is.
Here is what I did:
I found a sticket with it's MAC ID and some barcode:-
Check attachment 3
I looked up the mac and it belongs to "CONTAL OK Ltd" but they don't make embedded boards or anything, but apparently Contal belongs to MIFARE which is a part of NXP. I hope i'm not rambling here, but that didn't yield any results. Neither did the barcode. I searched Digikey, Mouser and element14 but nothing.
Under the sticker i found this:
Check Attachment 4
I searched a lot for this, but couldn't find anything anywhere...It looks to me like some number assigned by the PCB manafacturer.
I've identified the following parts from the board:-
Check Attachment 5
The two chips with heat sinks... what are they? cpu and gpu?
Other features of the board seem to be
- buzzer
- Real time clock
- 2 SATA ports
- 2 usb ports
- shitloads of gpio
Now for the most important questions:
Is this what is called an FPGA or is it a Microcontroller Board or is it a Microprocessor Board?
Can i program it?
Can someone explain the other mysterious parts in it like the three circular components on top right (*edit-bottom left) of the last image?
Where can I find datasheets if any for this board?
How to better identify boards better in the future?
