Author Topic: how to identify smd dual capacitor  (Read 1469 times)
Offline SILORAKTopic starter
  • Country: lt
« on: February 02, 2018, 06:09:22 pm »
Hi all. I am as green as it goes so sorry in advance. I have this part that I so far identified as an dual transistor but I am not sure. I would like to ask you if someone could identify  the value of it or at least is it rely what I think it is. It is from clarion cdc4-00 (model pu-2590a) on some kind molex connector and its designation is fil203. So far I have searched google for four days for any documentations on that model of changer or connector and came out flat  I will try to attach photo of the part but given as it is my first aptempt posting at any kind of forums it will probably go awry :)
Offline phil from seattle
Re: how to identify smd dual capacitor
« Reply #1 on: February 02, 2018, 06:53:27 pm »
capacitor? transistor? Hard to say but it looks like some sort of largish surface mount passive device.  Fil == Filter?  I'd guess capacitor just looking at it but maybe a ferrite bead. It's not clear are more than just 2 contacts. Seems like everything but the transistor is labeled filxxx.  What is the blue device on the far side of the PCB?  a connector?
  • Country: lt
« Reply #2 on: February 02, 2018, 07:32:57 pm »
Yes, the blue device is a 12 pin connector, and a blown out component definitely had  3 pins.
Offline chrisl
« Reply #3 on: February 02, 2018, 09:04:52 pm »
It is an EMI filter.  Something like this: http://search.murata.co.jp/Ceramy/image/img/A01X/G101/ENG/NFM21HC224R1A3-01.pdf
Measure the dimension and look for a replacement.
Cheers,
  • Country: lt
« Reply #4 on: February 03, 2018, 09:12:31 am »
