I have an older schumacher se-2352 where the rectifier diodes have fallen apart. The original diodes have markings s1308 0548 IOR but I can not seem to find anything with that manufacturer. This model is a 200am engine start 35amp cast charge and 2 amp slow charge. Is there a rule of thumb on what voltage and amp ratings these two stud mounted diodes should be?
I've worked with stud diodes 20 times larger than that and stud diodes 5 times smaller than that and never saw one come apart like that unless something blew out.
Maybe they were underrated to begin with.
One thing though, if it was a 50 amp diode and you went with 100 amp that should be ok, and if they were 100 amp and you went with 200 amp that should be ok, and if they were 50 amp and you went with 200 amp that should be ok too, but they should be a similar size or an easy mod to a bigger size. What i would do is measure the package and then find a diode in the same size package as a reference for the current rating, then maybe go 1.5 times that or something for reliability.
For the voltage rating you should probably go minimum 100 volts if they are on the secondary. I doubt they are on the primary.
I would also SOLDER the wire to the top lead i would not use quick connectors like in the pic.
Note you may have to drill out the holes a little if you go with a bigger size but you have to be careful about that.
Also, the diodes may not come with any mounting hardware so you may have to buy that separately.
Also, check to see if there is any insulator pad beneath the diodes. I dont think there is but if there is you need that too.
It's also possible that only one has a pad.
It's also possible that one (or both) are "R" versions that have anode and cathode leads reversed. You should check for that it's very important.
I've worked with diodes that are as big and flat as hockey pucks, and diodes that have a body size about the size of an 8 ounce can of tomato paste and the bolt on the bottom being 1/2 inch diameter and the lead coming out the top (not a solder stud like those in the pics) was 8 gauge wire with a huge ring lug connector at the end for bolting to something else to make the electrical connection to the anode. They are pretty amazing devices.
