Isn't there a 3.3V regulator on the programmer?The listing says it can deliver 3.3V
Shorting the 5V USB rail to GND isn't an issue. The USB standard requires protection from shorts be incorporated into the USB port.However, shorting USB power to a higher voltage might be a different story, never tried it.
