.. I'm not sure about the LTC1943, typo maybe?
Yes,I meant ltc2943 (there are also many others). High side has the advantage in some applications because you can share ground but is more difficult to implement unless if you use one of these ICs.
Sent from my Nexus 5 using Tapatalk
