Author Topic: need help for identfy component  (Read 456 times)
Offline EdisHPTopic starter
  • Country: lt
« on: August 03, 2024, 11:34:49 pm »
Hello, I have a car battery charger it is rated 4A, and need to identify sot23-6 (I think SMPS controller) pin 1. Gnd 2. FB 3. ? 4. CS 5. VCC 6. FET GATE.  Marking 2259 13121G. Thanks for help.
« Last Edit: August 04, 2024, 11:08:28 pm by EdisHP »
  • Country: lt
Re: need help for identfy component
« Reply #1 on: August 04, 2024, 07:26:35 am »
More foto
  • Country: lt
« Reply #2 on: August 04, 2024, 07:29:05 am »
  • Country: lt
« Reply #3 on: August 04, 2024, 09:30:06 am »
Or how can I pick another controller, what main characteristics to look at?
Offline floobydust
« Reply #4 on: August 05, 2024, 12:19:35 am »
I could find nothing matching those markings and numbers.
But it looks very close to On-Bright OB2262 same pinout. Original might be made by them as a guess "OB2259" which it could be? But no data. Sometimes they make crap IC's and erase them from the Internet lol.
Normally I would expect something else to have died in the charger, like the capacitors or mosfet etc.
Another sub is SG6848TZ in SOT23-6, or Chip Rail CR6848S. Both are 70kHz as well.
This website is maybe OK to ID SMPS IC's, it does need an update though. https://remont-aud.net/ic_power/
  • Country: lt
« Reply #5 on: August 06, 2024, 07:45:08 pm »
Thanks for help! Yes, here was burn out more components (MOSFET, resistors... ) I already replaced them, but still not working. Only this sot23-6 left... I will check your advice later. Thanks.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #6 on: August 06, 2024, 10:28:08 pm »
I'm guessing maybe it's a pin to pin replacement for an OB2281.
https://www.on-bright.com/en/index/product/detail/cid/150/id/405.shtml
