Quote from: hamster_nz on May 30, 2015, 07:05:04 amCompletely off-topic: Are you the guy behind Hamsterworks? Thanks for your explonation about the ADAU1761, helped me out a lot with a schoolproject!
do programs access the com port directly or does windows have a DLL?
Modern versions of Windows do not allow any direct access to hardware such as serial ports. You can use API calls to do it, or you can use the com port file devices. This blog post talks about it: http://stackoverflow.com/questions/237487/basic-example-of-serial-communication-with-windows-xp-win32VB.net in Visual Studio gives you simple ways to access them, and is available free.
I do use visual studio ultimate but I just wounded if windows had a DLL
