Author Topic: how does posting math notation work?  (Read 230348 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: October 10, 2020, 08:26:15 am »
I'd like to post a question with a math formula. I think there is a way of doing it but see no instructions.
« Last Edit: October 10, 2020, 09:15:14 am by Simon »
Offline IanB
Re: how does posting math notation work?
« Reply #1 on: October 10, 2020, 08:33:13 am »
Go to MathJax sandbox to get your syntax right, for example like this: http://jbergknoff.github.io/mathjax-sandbox/#JCRjPVxzcXJ0e2FeMitiXjJ9JCQ%3D
Then paste the formula into your post surrounded by double dollar signs:
$$c=\sqrt{a^2+b^2}$$
The reason for using the sandbox is that preview doesn't work in the editor here, so you need to use an external tool to see what your formulas will look like before posting.
The following users thanked this post: Wimberleytech, timenutgoblin, RJSV, Simon_RL, legrady, MathWizard
  • Global Moderator
« Reply #2 on: October 10, 2020, 08:34:25 am »
Thank you.
  • Global Moderator
« Reply #3 on: October 10, 2020, 08:35:24 am »
But is there a list of notation codes somewhere? as it is I use two programs with different methods of doing the same thing, I am sure this will be a third.
Offline IanB
« Reply #4 on: October 10, 2020, 08:38:57 am »
It's basically LaTeX math notation. I usually Google that to find tutorials and crib sheets.
« Last Edit: October 10, 2020, 08:45:41 am by IanB »
  • Global Moderator
« Reply #5 on: October 10, 2020, 08:41:31 am »
Ah OK, now I know what to google: https://oeis.org/wiki/List_of_LaTeX_mathematical_symbols It's certainly not responding to the keywords that open office uses.
The following users thanked this post: MathWizard
Offline IanB
« Reply #6 on: October 10, 2020, 08:45:01 am »
This seems to be a good reference:
https://en.wikibooks.org/wiki/LaTeX/Mathematics
  • Global Moderator
« Reply #7 on: October 10, 2020, 08:48:02 am »
It's the long fraction line that seems to be missing, i think I have to use an over line on the denominator
No it's a \frac:
$$ \frac {3-2s} {s^2-4s+9}$$
Offline IanB
« Reply #8 on: October 10, 2020, 09:09:22 am »
You can do it either way. For example, this will work too:
{3-2s}\over{s^2-4s+9}$${3-2s}\over{s^2-4s+9}$$
  • Global Moderator
« Reply #9 on: October 10, 2020, 09:11:03 am »
Ah, that is what I was hoping but did not see it. in Libre office you just write "over"
Online Ian.M
« Reply #10 on: October 10, 2020, 10:50:29 am »
Mathjax 2.7 documentation: http://docs.mathjax.org/en/v2.7-latest/
The original thread where Dave decided to enable Mathjax: https://www.eevblog.com/forum/suggestions/latex-for-eevblog/
Online Doctorandus_P
« Reply #11 on: October 12, 2020, 11:31:39 am »
Write it on a piece of paper.
Make a picture of it.
Post it.
The following users thanked this post: legrady
Offline mathsquid
  • I like math.
« Reply #12 on: October 13, 2020, 02:41:19 am »
So just put latex code in here and it works?
$$\sum_{n=1}^\infty \frac{1}{n^2} = \frac{\pi^2}{6}$$
Edit: Sweet.
Offline dnwheeler
« Reply #13 on: October 13, 2020, 09:50:08 pm »
\over and \frac are not equivalent. There is even a visible difference in the examples above.
Offline IanB
« Reply #14 on: October 14, 2020, 02:58:53 pm »
Using \frac:
$$\frac{3-2s}{s^2-4s+9}$$
Using \over:
I don't see any difference. How are they different?
Offline dnwheeler
« Reply #15 on: October 14, 2020, 08:31:54 pm »
Interesting. It appears to be some sort of rendering issue. In the previous posts, the "frac" line is clearly 1 pixel higher than the "over" line. In your post, they look the same, but as I'm typing this, the copy of your message shown below the editor shows the "over" line 1 pixel higher.
FWIW, I see the same behavior on the Chromium version of Edge and with Chrome (on a Windows 10 system).
There are other technical differences discussed here: https://tex.stackexchange.com/questions/73822/what-is-the-difference-between-over-and-frac
Offline IanB
« Reply #16 on: October 14, 2020, 09:22:40 pm »
So it's a case of \over being a TeX primitive whereas \frac is a LaTeX macro with more robust behavior?
However, I am with Knuth who apparently said that \over is a more natural syntax for mathematicians. As long as I see \over rendering properly it is the one I would prefer to use. I find \frac more awkward as it doesn't support a linear thought process when writing equations.
Edit: apparently \frac also uses a form of \over internally when it expands the macro.
« Last Edit: October 14, 2020, 09:25:16 pm by IanB »
Online RoGeorge
« Reply #17 on: October 14, 2020, 09:35:25 pm »
Enclose the formula between backslash dollar if you need an inline formula, for example like this one \$\Phi = BA\$, placed in a normal conversation.
Sometimes I use https://www.codecogs.com/latex/eqneditor.php as an online editor, good to see the rendered formula, because the forum shows the rendered formula only after posting, it does not render it at preview.
LATER EDIT:  Found an older post with a clean example in it.
Latex enclosed by backslash dollar will render it inline, when enclosed by double dollar will render centered, on a new line.
Example:
From Faraday's induction law, the induced voltage \$V\$ in an \$N\$ turns coil will be:
$$V = -N\frac{\vartriangle \Phi}{\vartriangle t}$$
where \$\Phi\$ is the magnetic flux
The Latex render will be seen only after posting the message, not at preview.
« Last Edit: October 14, 2020, 09:44:57 pm by RoGeorge »
Online RoGeorge
« Reply #18 on: October 14, 2020, 09:57:31 pm »
Trying a new one
\[\vartheta=2\pi  \tag{5.5}  \label{eq:best}\]
Space between consecutive formulae
    \mathbf{A}\textbf{B}  \tag{5.6}  \label{eq:special}
A reference to eq. \eqref{eq:best} and a cross-reference to \eqref{eq:special}.
Trying a new one
« Last Edit: October 14, 2020, 10:38:27 pm by RoGeorge »
Offline Andy Watson
« Reply #19 on: October 14, 2020, 10:35:53 pm »
And can I reference a previous post. Like equation \eqref{eq:best} ?
Apparently I can !
« Last Edit: October 14, 2020, 10:37:25 pm by Andy Watson »
The following users thanked this post: RoGeorge, emece67
Offline wizard69
« Reply #20 on: October 16, 2020, 04:45:22 am »
Interesting thread as i never considered math posting here.    Sadly this doesn't work on an Iphone with MathML turned on.   Not sure what is going on there but it works fine on Firefox on Linux
« Reply #21 on: October 18, 2020, 11:31:22 pm »
Yeah, it does, it's just that the site is noticing you're on a phone and serving a 'phone' version of the site. Go to the bottom of the page, select 'menu' and then 'full site'.
Offline Terry Bites
« Reply #22 on: January 08, 2021, 02:21:08 pm »
of course you can just do a screen shot and stick it in as an image
« Reply #23 on: January 08, 2021, 02:26:21 pm »
I can see how that would appeal to someone for whom full stops and starting a sentence with a capital letter seems too onerous.  >:D
The following users thanked this post: Andy Watson, Jacon
Offline TimFox
« Reply #24 on: January 14, 2021, 08:17:16 pm »
I normally use the equation editor in Microsoft Word to generate equations to be included in Word documents.
Is there a simple way to include such an equation into a post here?
