Author Topic: How do you screw stock microscope mount to the table?  (Read 2977 times)
Offline u666saTopic starter
  • Country: ru
« on: September 01, 2023, 02:55:21 pm »
Me honestly have to clue how he did it. But I have to figure it out. Attached pics. Otherwise I'd have to pay $110 for something like this custom made:
The mount I have is attached in 3 photos at the bottom of this thread.
« Last Edit: September 01, 2023, 04:07:50 pm by u666sa »
  • Country: ru
Re: How do you screw stock microscope mount to the table?
« Reply #1 on: September 01, 2023, 04:06:43 pm »
Which is yours?  The parts in the still from the youtube video or the 3 photos?
The 3 attached photos.
Offline wasedadoc
« Reply #2 on: September 01, 2023, 04:11:17 pm »
Looks like you need to make a hole in the tabletop for the threaded part in 2023-09-01_17-51_1.png to just fit through.  Are there any more pieces you have not shown?
  • Country: ru
« Reply #3 on: September 01, 2023, 04:38:24 pm »
You see, how he screw the stock mount that microscope comes with into table?
This is the stock mount
I want to figure out how to screw the pole from the stock mount into table. Making the hole in the table is no problem. The problem is that table is thick.  :popcorn:
Offline Doctorandus_P
« Reply #4 on: September 01, 2023, 05:04:40 pm »
Use a longer bolt then.
As an alternative, you can also use the stock table, rotate it a bit and then put something heavy like a power supply on top of it. This is at least an easy temporary solution.
« Last Edit: September 01, 2023, 05:06:13 pm by Doctorandus_P »
Offline wasedadoc
« Reply #5 on: September 01, 2023, 05:24:01 pm »
Now that I see the large plate, that changes things.  Does the bolt with with head for an Allen key unscrew and come out of the black cylinder?
The following users thanked this post: u666sa
  • Country: ru
« Reply #6 on: September 02, 2023, 12:41:29 pm »
 :palm:
Yea, I now realize that it is a bolt after all. So I'm getting a longer bolt and two flat wide heavy washers.
