Author Topic: LTspice IGBT HGTG12N60A4D  (Read 503 times)
Offline MaxTsvTopic starter
  • Country: bg
« on: August 19, 2022, 05:15:54 pm »
Hello guys,
I am new to LTspice, and I am trying to simulate a simple circuit, including an a bit ol IGBT - HGTG12N60A4D, in LTspice.
It appears that there is no simulation file for this particular item, may I ask you how you usually go thru an obsticle like this one? Having the datasheet and NIGBT or PIGBT symbols in LTspice, can I get it done somehow? What procedure or approach should I use in this case?
Thanks a lot!
