So, I should just add two more gate resistors with the same value of R6 and R16, such that each MOSFET has a resistor connected to its gates and remove the ferrite beads. Correct?
Correct.
One of their app note says under headings `Protecting the FET Gate and DSG Pin` and `CHG Circuit` it says:
A zener diode may be desired between the gate and source to protect the FET VGS from excessive voltage
May be it's designed for redundancy. Thanks for pointing it out, I will get it clarified with them.
Weird. Note that, if you do use a zener or TVS to protect gate voltage: put it "outside" of the gate resistors. The resonant loop created between a zener's capacitance and an active MOSFET typically causes oscillation during switching. Making sure that the loop between MOSFET and zener includes a resistor, prevents oscillation.
I don't know what they would be protecting against, so I might suggest one of:
1. Nothing
2. A simple zener diode like 1N5244 (or an SMT equivalent)
3. A TVS like P6KE15A or SMAJ15A
Diode D6 is a flyback diode, its purpose would be to clamp PACK+ near PACK-. It would be a pulse current when the discharge FET opens under load, have a fast response, and stand off the normal operation voltage of the battery plus any transient. (they have mentioned it in their reply they have posted above)
Yeah, I got that. That doesn't say anything about the diodes being in parallel, or the one diode doing the same thing already.
The one diode will do both already, D6 isn't needed.
The above schematic I attached is a reference schematic from Ti. My system is a different from theirs. I am a beginner and felt it is best to modify the above schematic to my requirements than to create one from scratch. I will be using a battery that will measure 28.7v when fully charged. I would like to limit the voltage build up to a 30.1v. But I could not find a TVS diode rated at 30.1 so I went with the closest value that is 33v.
I haven't accounted for transients while choosing the diode, Should I?
Edit : Can I apply 50% derating on the capacitors from the nominal voltage - 40v ?
Ah. 33V will be fine then.
What is this powering, or being charged by? What kind of transients are you expecting?
If a charger is connected which is higher voltage or current, and attempts to overcharge the battery, what happens? Should the diode absorb all that excess energy? Should the pack voltage be allowed to float up so that no charging current is drawn? What is that hypothetical charger likely to run at?
What kinds of loads will the pack see? Inductive, capacitive, motors, controllers, converters? Regenerative or dumping? (Most controllers and converters will have capacitance at their inputs, due to local filter capacitors needed for their switching circuitry.)
Capacitors can be rated for:
- Electrolytic or polymer: 35 or 50V
- Ceramic or film: 50-100V
- Don't use tantalum
Most capacitors will be ceramic, because they're small.
C2 I'm guessing can be rated for less voltage. RTFDS to see what that pin charges up to. At 1.5uF it will be a larger ceramic (1206 size?) and may be rated 16-50V. Electrolytic would probably be okay, too.
Ceramic: prefer X7R for general purpose, and C0G under 1nF. For X7R, check the characteristics. If you can't find a char. sheet, don't use it. (Note, some brands keep these data on their website, not linked from the supplier. So you have to poke through their listings to be sure...) You're looking for a plot of capacitance versus DC bias voltage. Make sure it has adequate capacitance at the voltage used. -30% is a typical threshold.
