Author Topic: quiescent current of opamp  (Read 495 times)
Offline JwillisTopic starter
« on: September 28, 2019, 04:04:14 am »
On the OPA445 the quiescent current is typically ±4.2 mA . That means that the positive and negative will draw ±4.2mA with no load. How do I calculate the current at the supply pins under full load? Or am I over thinking this?
https://www.ti.com/lit/ds/symlink/opa445.pdf
Offline ledtester
Re: quiescent current of opamp
« Reply #1 on: September 28, 2019, 05:16:32 am »
Starting with I_Q, just add the output current to the V+ current (if the output is sourcing current) or the V- current (if the output is sinking current).
So the max current through either the V+ or V- supply pin is i_Q + your max output current.
See also:
https://electronics.stackexchange.com/a/31032/95488
« Reply #2 on: September 28, 2019, 07:42:03 am »
Wow! That easy? I thought it would be more complex. Just wanted to make sure a 1 amp -15V regulator at the negative side would be enough without a pass transistor.
