Hi!
I am playing with a little breakout board from Adafruit, which has on board this adc
http://www.ti.com/lit/ds/symlink/ads1115.pdfI have read the datasheet, and it is mostly clear.
On the absolute maximum ratings, it states that Analog input voltage to GND must be –0.3 to VDD + 0.3
On my bench I am powering the breakout board, hence the adc with a 5V supply, but the signal I am analysing comes from the output of a linear position transducer, powered at 24v with a separate supply.
I am wondering, if I cut my 5V supply first, so that the output voltage of my sensor is still present I should be over the maximum ratings but the adc has no VDD...
Would this damage the adc or not??
