Author Topic: Unknown Component  (Read 1385 times)
Offline 2XTopic starter
  • Country: gr
Unknown Component
« on: May 05, 2018, 05:40:17 pm »
Hello,
does anyone knows what component is this at elow images? I measured on capacitor range with the multimeter and shows O.L. and  I measured on resistor range with the multimeter and shows approximately 6,7ohm. The colors on it are:
brown
white (on top)
red (on top)
gold
Offline ggkios
  • Country: gr
Re: Unknown Component
« Reply #1 on: May 05, 2018, 06:24:36 pm »
It is a coil of some value
The following users thanked this post: 2X
Offline ggkios
  • Country: gr
« Reply #2 on: May 05, 2018, 06:26:22 pm »
Inductor is a better fit actually.[emoji28]
  • Country: gr
« Reply #3 on: May 05, 2018, 06:37:13 pm »
Thanks a lot for the reply,
I found the below sites which shows how is the colour code of the inductors.
http://coil32.net/design/color-marking.html
http://coil32.net/online-calculators/inductor-color-code-calculator.html
Offline GerryBags
« Reply #4 on: May 05, 2018, 06:39:11 pm »
Try warming it up while measuring the resistance, it may be a thermistor. 6.7 Ohms seems like too much for a tiny inductor to me.
« Last Edit: May 05, 2018, 06:40:47 pm by GerryBags »
Online Zero999
  • 0999
« Reply #5 on: May 05, 2018, 08:20:49 pm »
You could be right about it being a thermistor, but wouldn't say a series resistance of 6.7Ω is unreasonable. It depends on the the value. The colour code suggests 1.9mH, which isn't a standard value. If it is 1.9mH, then I'd say a series resistance of 6.7Ω seems reasonable, perhaps even a little on the low side, going from data sheets of similar sized inductors.
https://www.rapidonline.com/pdf/64730.pdf
http://katalog.we-online.com/pbs/datasheet/7447462152.pdf
