Author Topic: How to approach vacuum tube circuits exploration?  (Read 1641 times)
Offline scuzzyTerminator
Re: How to approach vacuum tube circuits exploration?
« Reply #25 on: Today at 12:26:11 am »
Start with this:
Offline Kim Christensen
« Reply #26 on: Today at 12:41:47 am »
Start with this:
Looks like it's AI generated.   ::)
Offline Bud
« Reply #27 on: Today at 12:46:52 am »
Yeah, "Pentode mjube" and "Exloring vintage electronics amufiftion"  :scared:
Online BrianHG
« Reply #28 on: Today at 12:52:18 am »
Second reason- radios in those days almost universally had a single ended class A audio power output stage and these by nature are sensitive to power supply ripple, so a choke helped a lot to smooth things out. Solid state stuff  almost always has a class B push pull output stage that is nowhere near as sensitive to power supply rippple.
I thought the lack of sensitivity to PSP ripple in modern amps is because of the use of a negative feedback design.  IE, the output is fed back to a negative input to be compared with the positive audio input, completely ignoring whatever the power-supply is doing.
Offline coppercone2
« Reply #29 on: Today at 01:02:38 am »
I was going to do a tube but its alot of shit and not breadboard friendly for your first circuits.
I worked on repairing tube gear before, but I never did a circuit. Its tricky because its often HV.
You can use portable tubes (they have leads and are battery voltage friendly)
I bought a DIP-scale tube to experiment https://www.korgnutube.com/en
Offline Circlotron
« Reply #30 on: Today at 05:33:41 am »
Yep, NFB reduces sensitivity to ripple also.
