Here is my code history .txt. You can put this into your project folder, then right click on "other" folder in the project view window and add this file. You can see the miles of stuff I went through to figure out the few lines of code to change/add.
Pin Configuration can be added to the "header" folder in the same way.
Typically, I'm going to put each bank of memory on its own .inc file, too, added to the header folder.
And error levels, ditto.
Now to see those things, it's just a click, and you have that info side-by-side your current place in the code. Rather than scrolling through 5 miles of code AND losing your place in the code AND forgetting what you looked up by the time you have the code on screen, again.
But note, if you wanted these .inc files to be included, you would have to include them in the main .asm file. Like this:
#include Pin Configuration.inc
#include Error_Level.inc
You can do this up at the top of the file with the "#include list_16F57.inc," or if adding other .asm files, which you can add to "other" folder, you may put the #include anywhere you want that code to go.
None of the defines in the Pin Configuration are utilized, but it's nice to be able to click on it to quickly pull it up for reference. So as it is right now, there's no reason to include it unless you starting using these defined names in the code. It's also often handy to have a spare whiteboard.asm where you right/modify new bits of code, so you can scroll through the main .asm to reference while writing it.
**edit... apparently .inc files can't be uploaded. Will change Pin Configuration to .txt and you would have to change it back to .inc before adding it to "header" folder.
