Hello,
I am curious how CMOS chips are designed. Do they have onboard charge pumps to drive the gates of the mosfets on a CMOS chip?
If you are asking about microprocessors and larger logic CMOS widgets, here's a brief overview.
All the circuits are built around NMOS and PMOS devices. The simplest CMOS gate is an inverter. It has one NMOS device and one PMOS device.
- The gates of the NMOS and PMOS devices are tied to the input.
- The drains of the NMOS and PMOS devices are tied to the output
- The source of the NMOS device is connected to VSS (a culturally embedded name for "local ground")
- The source of the PMOS device is connected to VDD (a very embedded name for "the upper supply rail") at 3.3V.
For a 3.3V device the NMOS threshold voltage might be something like 0.7V and the PMOS threshold -0.7V. (More modern processes that run at 1.0V or even lower have very low threshold voltages.)
That means that the NMOS device turns on when its gate-source voltage rises above 0.7V. So if the input is pulled all the way to the upper rail, the NMOS device is really really on. The PMOS device will be cut off. The output will be pulled to ground.
If we pull the input down, then the PMOS device will begin to turn on, and the NMOS device will start to turn off. Eventually when the input gets to the lower rail, the PMOS pullup is really really on and the NMOS pulldown is cutoff.
NOR gates and NAND gates have slightly different topologies (for one thing, they each have two or more inputs). There are even more complex configurations, but most of the area on a die is taken up with pretty simple circuits. (Though a RAM cell is way more complicated than they tell you about in school....)
There was a time when really hot CMOS designers drew transistor level schematics. In the microprocessor industry, those days are pretty much gone. There are a few lonely holdouts, but most CMOS logic design is mediated by a logic synthesis process that translates descriptions in verilog or VHDL into netlists and layout.
The feature size number (like 45nm) used to correlate very closely with the length of a channel. So in a 250nm process, a typical inverter would be built with an NMOS device whose gate was 250nm long and 2500 nm wide. The PMOS device would have a gate dimension of 250nm long by 5000nm wide. Back then, the length of the channel was long enough that the 2x difference in electron mobility vs. hole mobility made a big difference. Modern processes with their very short channels have mitigated this difference a great deal.
So, no, there are no charge pumps to jack the gate up. But there was a time when microprocessors were designed with just one type of device -- many were NMOS only, others PMOS only. For NMOS only circuits, it is hard to get the gate all the way to the rail. (I won't go into why that's important, but it is, for certain kinds of circuits.) In those circuits there is a kind of charge pump called a "bootstrap" invented by Rueben Joynson at GE back in the late sixties or early seventies. But that isn't used today for silicon circuits.
Note that the above description is a simplification. Things are different with output drivers and input receivers. Connecting to an external contact creates lots of circuit issues that the interior circuit designers can safely ignore. Additionally, circuits like DRAM cells, SRAM cells, sense amplifiers, flip-flops, and latches often have circuit topologies that are far more complex than the simple switch network of a NAND gate. High performance, or low power, or high reliability designs also need to account for lots of effects and aspects of wires -- lateral coupling capacitance between wires, for example. There are even cmoplex "wear out" mechanisms that big league chip designers take into account.
I hope this was helpful. For a view of CMOS design circa 1990, I can highly recommend Dobberpuhl and Glasser "The Design and Analysis of VLSI Circuits" it may seem quaint in light of today's 14nm CMOS processes, but it was a great book back then...
