Author Topic: Homemade Soldering Iron Questions  (Read 7513 times)
Offline TorqueRangerTopic starter
« on: May 27, 2013, 08:29:28 pm »
I am using right now a Hakko 939 and has anyone every built a soldering station that is equal to JBC or METCAL ???
Offline IanB
Re: Homemade Soldering Iron Questions
« Reply #1 on: May 27, 2013, 08:32:57 pm »
You will not reproduce the hand piece or the soldering tips unless you have access to a well stocked machine shop and excellent fabrication skills, but there is no reason to think you couldn't reproduce a compatible base station and controls. I seem to recall Mike looked into that at some point...?
« Reply #2 on: May 27, 2013, 08:39:54 pm »
Well my Idea was to use a Hakko 907 handle  but build the heating electronics setup like the JBC ..
Offline IanB
« Reply #3 on: May 27, 2013, 08:45:56 pm »
The key functional element of those good soldering stations is that they have a temperature sensing element and a heating element very close to the tip of the iron, a low thermal mass, and a very fast temperature control loop with plenty of power behind it to hold the temperature steady.
Lesser irons have a big lump of copper in the tip to hold heat and compensate for a slower temperature control loop. It takes them longer to heat up and longer to recover if you suck heat out of the tip.
In contrast the higher quality irons make a virtue of not having a big lump of copper in the tip. Instead, as soon as you draw heat the drop in temperature is noticed and the iron instantly ramps up the heat supply to keep the temperature constant.
Offline Rufus
« Reply #4 on: May 27, 2013, 08:46:24 pm »
There is a 14 page thread about a DIY Metcal rf supply
https://www.eevblog.com/forum/projects/diy-metcal-13-56-mhz-rf-supply/
If you search the web you will find an open source soldering iron controller for conventional 24vac heater + thermocouple type irons.
« Reply #5 on: May 27, 2013, 10:58:37 pm »
Yeah I have been watching it some what But really looking for something JBC with out all the extra's like a Hakko 888 Basic...
Offline nukie
« Reply #6 on: May 28, 2013, 04:24:55 am »
forum member vzoole - shows you how you can use JBC handle with a Hakko station post #9
https://www.eevblog.com/forum/reviews/for-jbc-fans-out-there-jbc-tips-anatomy/
« Reply #7 on: May 31, 2013, 11:30:20 am »
Here is what I would love to make but use a hakko 907 iron instead
Offline Paul Price
« Reply #8 on: May 31, 2013, 12:03:00 pm »
Wheredoya get that handle head by itself and whatsit cost? I can easily build a MCU circuit with a thermocouple amp and power supply and a LED readout and pot to adj etc. for this powerful pencil. But what arrpox. cost of the handle and changeable tips?
« Last Edit: May 31, 2013, 02:19:11 pm by Paul Price »
Offline Rerouter
« Reply #9 on: May 31, 2013, 12:10:36 pm »
google "soldering pencil" plenty should turn up,
for something more specific in Sydney Australia, there is a large distrubuter known as "WES Components" and they have all sorts of replacement parts and pencils, and will give retail prices over the phone,
Offline nanofrog
« Reply #10 on: May 31, 2013, 07:00:12 pm »
Assuming you mean JBC, take a look at the following (US location, but they sell internationally and have good pricing).
T245 Iron: http://www.janelonline.com/jbc-tools-soldering-iron-t245-a-p/jbc-tools-t245-a.htm
Stand for T245 or T210 irons (connects to station for sleep/temp reduction signal from metal holding collar): http://www.janelonline.com/ad-sc-ad-sd-jbc-tools-soldering-stand-p/jbc-tools-ad-sd.htm
Tips for T245: http://www.janelonline.com/SearchResults.asp?Search=jbc+245+tips
Offline Mr Smiley
« Reply #11 on: May 31, 2013, 07:04:15 pm »
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
Offline Paul Price
« Reply #12 on: June 01, 2013, 12:44:40 pm »
Thanks for the hot tips about buying hot tips!
