Author Topic: Can I use an LM311 in a 4MHz crystal oscillator?  (Read 6456 times)
Offline PeabodyTopic starter
« on: April 01, 2024, 04:54:42 am »
I'm not sure what to look for in the datasheet.  I have the crystal and three LM311s.  Is there any chance one of them will work, and be stable?  This is just for a personal project, not a commercial design.
Offline Konkedout
Re: Can I use an LM311 in a 4MHz crystal oscillator?
« Reply #1 on: April 01, 2024, 05:11:57 am »
I think it work not at all or poorly at best.
I just checked the datasheet and confirmed my memory that the LM311 response time is 200 nSec.  That is probably a typical number (not worst case maximum.) But a complete cycle (one period) of a 4 MHz oscillator is 1/(4MHz) = 250 nSec.  The output needs to switch both up and down during one period.  This means to me that the response time MUST be no more than 250 nSec/2 = 125 nSec maximum, and probably less than that.
I think that if you want to use a comparator for this purpose, you probably ought to use one with a response time of 50 nSec or less.  I have never designed a crystal oscillator and I am not in a position to give you a design unless I were to spend some time working on it.
When using a crystal be careful not to overdrive it....
« Last Edit: April 01, 2024, 05:19:15 am by Konkedout »
« Reply #2 on: April 01, 2024, 01:41:44 pm »
Thanks very much.  That's what I suspected.  I was just hoping a comparator I had on hand would work.
Online Benta
« Reply #3 on: April 01, 2024, 06:32:25 pm »
You want to drive a crystal with a linear amplifier, not whomp it with a comparator output.
One of the best parts for this is the SN74LVC1GX04:
https://www.ti.com/lit/ds/symlink/sn74lvc1gx04.pdf
