Author Topic: Voltage Regulator Thermal Dissipation  (Read 1281 times)
Offline NivagSwerdnaTopic starter
« on: September 21, 2017, 04:06:37 pm »
Given a regulator such as NCP1117 providing 100mA @ 5V
If I provide the regulator with say 6.2V, 9V or 12V or 20V etc. how does that affect the thermal dissipation?  i.e. does it get hotter the higher the input voltage?
I looked at the datasheet but can't puzzle that out. I would expect that I should supply nearer to 6.2V than 20V?  (1.2V max dropout)
Thanks in advance
Offline rdl
Re: Voltage Regulator Thermal Dissipation
« Reply #1 on: September 21, 2017, 05:28:37 pm »
Dissipation in watts for a linear regulator is Vin - Vout x I
The higher the input voltage the more power must be dissipated as heat.
Offline cdev
« Reply #2 on: September 21, 2017, 05:42:03 pm »
I have a related question about voltage regulation and heat in a GPSDO controller context which I think I'm going to post in its own thread, maybe in the metrology section.
« Last Edit: September 21, 2017, 05:54:07 pm by cdev »
Online Zero999
  • 0999
« Reply #3 on: September 21, 2017, 06:23:54 pm »
Dissipation in watts for a linear regulator is (Vin - Vout) x I
Corrected: you forgot the brackets.
Yes, the higher the input voltage, the higher the power dissipation.
Although it's usually negligible, the current flowing out of the regulator's 0V pin can be significant too. Especialy in low drop-out regulators, when the output voltage is fairly close to the input voltage. This normally isn't a matter for thermal design. It's more important when dealing with power consumption.
Offline Damianos
  • Country: gr
« Reply #4 on: September 21, 2017, 06:24:59 pm »
I think that it is better to answer by yourself. It needs just a little thinking.
A linear voltage regulator is a box that somehow observes the output voltage and tries to keep it stable, by adjusting the conductance from input to output. Lets say that someone inside measures the output voltage and adjusts a resistor that the input with the output. This creates a power loss that converted to heat.
The input power is Pin = Vin * Iin
Respectively the output power is Pout = Vout * Iout
Also according to the above description the Iin is about equal to the Iout
The power loss is the difference of the above two. Calculate it.
« Reply #5 on: September 21, 2017, 11:23:15 pm »
Thanks for the responses.
Looking at a related datasheet I found...
PD = (VIN – VOUT) IOUT
TJ = TA + PD (omegaJA)
and a no heatsink 65 °C/W
I think that probably tells me what I need to know.
Thanks
