Hi Ian,
(newbie here)
It is hard to say what is the total power requirement for your robot without info about motors and the voltage of a single Ni-MH battery you use.
However, I would start with the following.
Two 18650 Li-ion batteries connected in series will give you a voltage between 6V and 8.4V. That should be enough for powering motors, however, buck converter might be needed.
For powering RPI Zero you would definitely need a buck converter capable of delivering 5V 1.5A. There are plenty of such DC-DC buck converter modules, just peek one that suits the RPI power requirement.
I would use a module based on TP5100 IC for charging. It can handle two 3.7V Li-ion batteries connected in series.
For powering that module you might use a USB charger with PD / QC function that can provide 12V, and a PD trigger module, based on CH224K, for example.
