I desoldered Ceramic Capacitors(C804 and C805 1kV 1nf in the below schematic) which is right beside bridge diode(TS4B05G) of 21inch CRT TV(220v 80watts).
But Unfortunately,the thickness of these Ceramic Capacitors' pin is thick and so tough,and It already have been bent in the PCB of 21inch CRT TV,While I desoldered these Ceramic Capacitors,Some of its soldering pad was torn apart(damaged).
As soon as I confirmed that its capacitance was almost the same as 1000pf with LCR T4 meter, I narrowly resoldered these Ceramic Capacitors back to PCB,But there was already hardly any pad left in one of soldering pad(which is just above D815 and it is C805 in the schematic).
So I Scraped off the varnish from its trace and It exposed some of copper and I soldered to connect it to pin of Ceramic Capacitor by applying heavy doses of solder like below picture.
I confirmed that it has continuity with its adjacent components But As far as I know, Fairly high amphere and high voltage flows in the trace of bridge diode,So I doubt that It is really enough just soldering exposed some of copper to pin of Ceramic Capacitor with heavy doses of solder..
