a series resistor to limit current and a set of regular diodes to clamp pos/neg, use set of two diodes to get slightly higher voltage
Quote from: langwadt on August 01, 2015, 02:33:54 pm a series resistor to limit current and a set of regular diodes to clamp pos/neg, use set of two diodes to get slightly higher voltage do you mean this?
