Author Topic: What does "HAC" mean for a T2A, 250 V HAC, slow-blow Fuse?  (Read 1671 times)
Offline metrologistTopic starter
« on: February 10, 2020, 08:00:55 pm »
All I find is stuff about Honda and hill-climb assist.
Offline ArthurDent
Re: What does "HAC" mean for a T2A, 250 V HAC, slow-blow Fuse?
« Reply #1 on: February 10, 2020, 09:17:28 pm »
"HACR stands for “Heating, Air-conditioning, refrigeration” For equipment or in a panel or enclosure feeding the HACR rated equipment."
Apparently these fuses are rated for inductive loads like motors, etc., and can stand repetitive inrush current on equipment start-up. It would be wise to replace with the same type and rating of fuse. I found one size on Amazon.
https://www.amazon.com/Edison-HAC-R-30-Buss-FUSE-HACR30/dp/B009EC7F1W
Offline tooki
« Reply #2 on: February 10, 2020, 09:20:29 pm »
If you google "HAC fuse -honda", you quickly find reference to the Bussmann HAC-R fuse line. However, it seems to be larger, high-current fuses.
It looks like HAC-R was a series of current-limiting fuses: http://www.cooperindustries.com/content/dam/public/bussmann/Electrical/Resources/product-datasheets-a/Bus_Ele_DS_1038_HAC-R.pdf
Offline tooki
« Reply #4 on: February 10, 2020, 10:13:42 pm »
This is the actual part number for the fuse as it comes from the MFG. I don't HAC should be listed.  :-//
https://www.newark.com/littelfuse/0213002-mxp/fuse-cartridge-2a-5-x-20mm-slow/dp/26K7595
« Reply #5 on: February 10, 2020, 10:14:15 pm »
It goes in a low power device like an O-scope.
Offline tooki
« Reply #6 on: February 11, 2020, 12:22:50 am »
So I guess they just needed any old slow-blow fuse and got a good deal on those HVAC ones.
