Zin(L=λ/8) = Zo * (ZL + j*Zo) / (Zo + j*ZL)
That's correct so far. Take it a step further. Try placing Zo = 0 (for a shunt TL) or Zo = inf (for an open TL).
Why narrower bandwidth compared to other solutions ?
There are tradeoffs between constructing filters as stubbed lines versus hybrid stub/element filters.
I am very confused with your terminology used in the above sentence quote.
I do not get what you mean by this sentence.
First, I will clarify what I meant by that statement. I meant the difference between constructing a filter out of microstrip line elements (or CPW) and conventional elements (i.e. conventional inductors or capacitors).
Essentially what you're doing is performing an impedance transform, it can also be interpreted as an impedance match. The stripline impedance matcher has a limited bandwidth, this can be alleviated by using stepped transmission line sizes, or other geometries, such as triangular or exponential to increase the bandwidth. i.e. For an impedance inverter layout, the more steps (thus the more poles, and the more stubs) will translate into a larger bandwidth.
For example, a good measure for a single stub capacitor would be the ratio of Zc/Zo, where Zc is the capacitor impedance.
Alternatively, again if we look at a single stub case, we can see that the bandwith (and thus Q) is:
Q = Wo*L/R = 1/(Wo*R*C)
So to increase the bandwidth you would decrease Q. You then would need to either decrease L, or increase the R or C.
Obviously, as you add more poles (either series inductance or extra stubs) the above relationship becomes significantly less trivial.
