Good Idea Fsck, for the second DMM I think I am getting the EXTECH EX430 as c4757p suggested!
Thanks for the help guys! Much appreciated!
May be get two of equal quality?
Let me explain my frustration and see if that annoying feeling may get you too.
What I found most annoying with multiple DMM is: I am always temped and switch to my better DMM to "there" and see what the reading really is "there". So it is like as if I have just one.
I have 4, a cheap DT830B (2000 count), a cheap 2000 count Radio Shack, a 4000 count Radio Shack, and a 22000 count UT61E.
I rarely swap out the DT830B because I calibrate it to be +-1 digit from my UT61E for the ranges I use. The two RShack are not calibratable. I know from experience both are +- 3 to 5 mV (and +- 3 to 5 count whichever is larger). So, when I have a four-meter arrangement such as: In-Volt, In-mA, out-Volt, out-mA. I often end up thinking: what really is the In-Volt exactly, let me switch my 22000 count meter to there and put the RShack here. Wait, what is really is the current, let me switch my 22000 count meter there and put the RS there. So I am swapping back and forth as if I have only one DMM. Well, actually as if I have just two. After I calibrated the DT830B, it tracks the UT61E well and I feel I get the "right reading" even while it has only 2000 count. So what really bugs me is not the accuracy or precision but the inconsistency when the two RS are not consistent with itself, and not consistent with the other meters. Small delta at merely +- 3-5 counts but it bugs me enough that I don't feel I have a reading.
A bit silly to be bothered by consistency so much, I admit.
