Pre tinned leads where fairly common
Tin plated yes, solder no! What you have are probably what are called "solder pulls". Those are used chips that are unsoldered from a circuit board vs "socket pulls" which are used ICs that are taken from sockets. Both types are very common in the surplus/ used IC market.
If you want to be certain, then look up the manufacturer's data sheet for the part. I THINK a few manufacturers offered pre (solder) tinned parts but I have used probably over 100,000 ICs of that vintage and I've never seen a pre-soldered part.
