Hi ,
I`m dealing with one schem of efficiently charge / discharge of lithium assembly (6P) and stuck with one problem.
In case charge / discharge Li-ion there are already many different devices , but main problem with them is heat - all discharge will go into heat.
This is not problem with one battery - but can cause an real problem in case scaling this job
So idea is to use hybrid inverter - solar input as load and AC output and source for charging .
In case of high input voltage of inverter can be manage with serial connection of few assemblies and higher q-ty input BMS .
But main concern how to limit solar input current - many of them use mppt and draw maximum power of the solar input .
This can shutdown BMS and stop discharge.
Maybe someone use more hybrid inverters and maybe some vendors have some SW limitation for solar input ?
Thanks in advance .
