Are r25 / r26 integral in the darlington package
You have darlingtom marked with a rectangle drawn with a dashed line.
R25 is insied, R26 is outside.
If R26 would be integrated in Q17 darlington than package would have to have 4 pins.
but r27 value is not shown, would this also be 0.05r
Certainly not.
Voltage drop at this resistor will be at least 0.7V higher than at those 0.05r. I suppose its value depends on exact transistors used (for example on h21e of Q19..Q21).
It is in base of output transistors and not emitter.
