hi.
i have this max2650 amplifier and i want to know what value i need for its blocking capacitor.
this is what the datascheet says:
As shown in the Typical Operating Circuit, the MAX2650 is easy to use. Input and output series capacitors may be necessary to block DC bias voltages (generated by the MAX2650) from interacting with adjacent circuitry. These capacitors must be large enough to contribute negligible reactance in a 50Ω system at the minimum operating frequency. Use the following equation to calculate their minimum value:
cblock = 53,000/f = (pf)
where f (in MHz) is the minimum operating frequency.
im to new to this to understand how to calculate that.
if my freq. is 18Mhz...
will it be 53/18 and 2.9 pF for capacitor?
or:
(53000/18000000 = 2.9 -03 is 2.9 nF)?
what is the correct calculation?
The first answer is incorrect.
The second answer is correct, but they assumed you would, by using the frequency in MHz, get a result for C in pF of approx 2900 pF which (in your case),you would convert into nF.
By expressing f in Hz, instead, your result was in uF, which you converted to nF,still getting the same answer.
