Poll
I was wondeing if anyone has any information on this oscilloscope, like manual, specs, etc.
Links
0 (0%)
Suggestions
0 (0%)
Information
0 (0%)
other
0 (0%)
Total Members Voted: 0
Author Topic: Heathkit Analog Tube Oscilloscope Model HO-10  (Read 8362 times)
Offline zker666Topic starter
  • TeraVoltLabs
    • TeraVoltLabs
« on: July 18, 2010, 07:53:29 pm »
I have an ancient Heathkit HO-10 oscilloscope, and i have no idea what the hell to do with it!!! I cannot find any useful info on the internet about it, and i was wondering about the specs of this certain scope. It has to be as well back as the mid 40's and it is a dual trace o-scope, 10mHz bandwidth, and it wont work, but thats an easy fix. The 1V2 tube is busted and im ordering a new one, but in the mean time i want to know some information on it. PLEASE HELP!!!
Offline DJPhil
Re: Heathkit Analog Tube Oscilloscope Model HO-10
« Reply #1 on: July 18, 2010, 08:00:42 pm »
Here's a start: http://www.vintage-radio.info/heathkit/
It's a monitor scope, compact and designed to be part of a permanent installation.
Hope that helps. :)
Offline slburris
« Reply #2 on: July 18, 2010, 08:11:44 pm »
You can find the operation manual, parts list, and schematic at:
http://www.mods.dk/manual.php?brand=heathkit
Scott
  • TeraVoltLabs
    • TeraVoltLabs
« Reply #3 on: July 19, 2010, 12:14:56 am »
Thank you both so much helped alot :)
Zachary
alm
  • Guest
« Reply #4 on: July 19, 2010, 09:41:50 am »
If it's from the 40s, it's probably not triggered or calibrated, which makes it of limited utility compared to the 'modern' scopes like Tektronix made since 1960 or so.
  • TeraVoltLabs
    • TeraVoltLabs
« Reply #5 on: July 19, 2010, 06:59:43 pm »
Yeah, it has a quite high calibration, within ±6%, which is a pretty accurate scope for the 40's! But, it isnt triggered, so repetitive signals have to be adjusted on the frequency range just right so you can see the changing waveform, but, it doesn't matter about the accuracy, i just really need it to see changes in frequency, like for a pwm circuit, oscillator, 555, etc.
alm
  • Guest
« Reply #6 on: July 19, 2010, 07:24:54 pm »
Calibrated means that there's a graticule (grid), and the vertical and horizontal settings are marked with X V/div or Y us/div. This allows you to do simple measurements (with 3% tolerance or so). I believe calibrated oscilloscopes were introduced in the 40s, but I'd expect Heathkit to be a bit behind the 'big boys' like Tektronix.
  • TeraVoltLabs
    • TeraVoltLabs
« Reply #7 on: July 20, 2010, 01:50:09 am »
Yeah, it is one of the smaller models, but with ALOT more quality, and, plus, heathkit back then was a big name in the early 40's, because Tektronix was founded in 1946 i beleive, but it does have simple calibrations, but i really just need it to measure signals
  • TeraVoltLabs
    • TeraVoltLabs
« Reply #8 on: July 20, 2010, 01:57:59 am »
Check out my youtube channel, zker666, and my latest videos will be there reviewing the Scope.
