Author Topic: PCBwing and altium outputs, which is which?  (Read 5837 times)
Offline HypernovaTopic starter
  • Country: tw
« on: July 18, 2010, 11:21:12 am »
Trying to generate the necessary files to send to PCB wing and need some help on what files they want.
Not using silk screen. The top and bottom stuff is obvious enough but not sure about board edge and separate drill files
They want:
Gerber Top Silkscreen layer:
Gerber Top Solder Mask layer:
Gerber Top Copper layer:
Gerber Bottom Copper layer:
Gerber Bottom Soldermask layer:
Gerber Bottom Silkscreen layer:
Gerber Board Outline:
Excellon Excellon Format Drill File ( RoundHoles ):*
Excellon Excellon Format Drill File ( SlotHoles ):
Excellon Fabrication Drawing:
Excellon Nonplated Drill File:
Gerber Aperture For 274D Format:
Text Tool Size Report:
Text Readme File(Explain special process only):
What I got: (4:2 metric relative)
18/07/2010  09:04 p.m.               832 Main Board-BoardEdgeRout.TXT
18/07/2010  09:02 p.m.             3,092 Main Board-macro.APR_LIB
18/07/2010  09:02 p.m.             4,275 Main Board.apr
18/07/2010  09:04 p.m.             7,468 Main Board.DRL
18/07/2010  09:04 p.m.             1,552 Main Board.DRR
18/07/2010  09:02 p.m.             1,033 Main Board.EXTREP
18/07/2010  09:02 p.m.           300,254 Main Board.GBL
18/07/2010  09:02 p.m.            22,362 Main Board.GBS
18/07/2010  09:02 p.m.           112,567 Main Board.GD1
18/07/2010  09:02 p.m.            50,144 Main Board.GG1
18/07/2010  09:02 p.m.           323,710 Main Board.GTL
18/07/2010  09:02 p.m.            44,901 Main Board.GTO
18/07/2010  09:02 p.m.            22,569 Main Board.GTS
18/07/2010  09:04 p.m.               158 Main Board.LDP
18/07/2010  09:02 p.m.             2,981 Main Board.REP
18/07/2010  09:02 p.m.               566 Main Board.RUL
18/07/2010  09:04 p.m.             8,256 Main Board.TXT
18/07/2010  09:04 p.m.               379 Status Report.Txt
+two .cam files from the gerber output and the NC drill output.
