Hey, I am working on a project that requires two boards to communicate.
The idea is that when a input is given, a RS-NOR is flipped (to activate a relay) on another board up to about 10 meters away, then when pressed again it would flip the RS-NOR again to turn off the relay. I am having issues implementing a wireless solution. I have seen such chips as the Si4330 but am not sure how to implement it, or if it is overkill for my requirements.
How might I go about achieving this?
