Coaxial transmission lines cannot be much higher than, say, 125 ohms, in characteristic impedance (q.v.) due to the logarithmic dependence of the characteristic impedance on the dimensions.
However, a short length (without termination) of normal coax (RG-58/U 50 ohm cable, for example) into a high-impedance oscilloscope input (1 megohm in parallel with maybe 20 pF) will look like a high resistance (1 megohm) in parallel with that 20 pF plus the capacitance of the cable (95 pF/m for RG-58/U). When terminated with a 50 ohm resistor, it looks like 50 ohms almost-resistive at the other end.
