Definitely a beginner with a lot to Learn. I’ve got a Dell D6000 Dock that is shutting down the charger which I take to mean a short somewhere. I saw on my thermal camera this chip getting hot quickly before the charger shuts down. I believe this chip to be a MOFSET. I have searched for EMA2182 datasheet and come up dry.
Charger no longer shuts down with this chip off the board. With DMM in diode mode, red on the pad/pins 5-8 and black on 1-4 in order I read 0.481 V, for 1-3 and open for 4. Then I go back to pin 1 and the readings are 0.002V for pins 1-3. With black on pins 5-8 it’s open.
Resistance measures black on 5-8, red OL on 1-4. Red on 5-8 black on 1-3, 9.2 Mohm, 4 OL. Then 1-3 measure 1.6 Ohm.
This seems like 4 is a gate being opened to ground?
Is there an equivalent replacement for this chip?
Thanks for your help!
