Author Topic: Help identifying a five bands resistor from a Canberra 2022  (Read 967 times)
Offline Erik LTopic starter
  • Country: no
I had an issue with a NIM Canberra 2022 amplifier I recently purchased. The "holly smoke" started pouring out after I inserted it into my BIN and powered up the unit. After shutting down, removing, and opening the amplifier, I found that the current limiting resistors were burnt out, likely due to some defective tantalum capacitors. I identified at least three capacitors as shorted.
I am now trying to identify the resistors with the following color bands: wide silver, brown, black, black, and silver. The size of the resistors is approximately 2 mm by 6 mm. Typically, the color code ends with two silver bands.
Can you help me determine if these resistors are 100 Ohm or 1 Ohm 1/4 W or something else?
Thanks for your help!
Offline wraper
  • Country: lv
Re: Help identifying a five bands resistor from a Canberra 2022
« Reply #1 on: June 02, 2024, 11:11:36 am »
You literally have 8 of the same resistors, just measure them.
  • Country: no
« Reply #2 on: June 02, 2024, 11:13:14 am »
They are fried, no consistency in the measured values.
Offline pcprogrammer
« Reply #3 on: June 02, 2024, 11:26:09 am »
That is what I would do.
But as silver at both ends of the resistor is not normal, my guess is that you have to ignore the wider band and then it would be 100 Ohm 10%. To validate this you can also see what the supply voltage is and consider if the damage concurs with what you see. At 5V there is enough current to heat up a 100 Ohm 1/4W resistor, but would take a while to burn up. At 20V it is consuming 4W and can go up in smoke more easily. For 1 Ohm it would be 25W at 5V and that for sure would smoke it up real good.
Online Andy Watson
« Reply #4 on: June 02, 2024, 11:41:44 am »
Are there any legends on the pcb to indicate the component type? The sivler at boths ends, and the style of case makes me think that these are inductors (100\$\mu\$H 10\$\mu\$H).
The manuals for Canberra suggest that you can contact them for circuit diagrams - and other technical help. It might be worth contacting these people (who now own Canberra):
https://www.mirion.com/mirion-technologies-canbera-bnls-nv
« Last Edit: June 02, 2024, 05:20:18 pm by Andy Watson »
The following users thanked this post: tooki, srb1954
Offline wraper
  • Country: lv
« Reply #5 on: June 02, 2024, 12:14:22 pm »
You don't need consistency. You need one with lowest value and that looks like it could match the rings.
  • Country: no
« Reply #6 on: June 02, 2024, 06:03:34 pm »
This  topic can be closed.
The second ring wasn't brown but rather orange...
Silver: ~10 %
Orange: 3
Black: 0
Black: 0
Silver: x 0.01
The resistor value is 3 Ohm 10 % 300x0.01=3
Thank for your help!
Offline daisizhou
  • Country: cn
« Reply #7 on: June 02, 2024, 10:40:13 pm »
This resistor looks like a carbon core resistor, but it is not easy to buy it.
daisizhou#sina.com #=@
Offline wraper
  • Country: lv
« Reply #8 on: June 02, 2024, 10:56:26 pm »
And you shouldn't as they're garbage.
Online Andy Watson
« Reply #9 on: June 03, 2024, 06:54:46 pm »
Orange ! My eyesight might be fading but orange?
Something I suspected but only found out for sure today: The doulbe-thick silver starting band indicates an indicutor, specifically one with "mil-spec" marking. So they are 10\$\mu\$H inductors 10% tolerance. (Or 30\$\mu\$H, if you insist on orange ;) )
Offline wraper
  • Country: lv
« Reply #10 on: June 03, 2024, 07:43:09 pm »
^I never seen inductors of this package style but found some while googling. Also I found about silver band being military identifier, although not sure if it's inductor exclusive. Band is brown on the picture, however considering there are signs of overheating paint could have changed the color. Also considering these look like carbon composition resistors https://www.ebay.com/itm/144613216641 , those that did not fail entirely could have drifted to high side a lot, they're notorious for this. In any case I think it's worth to check their inductance or break one apart to see what's inside.
« Last Edit: June 03, 2024, 07:45:19 pm by wraper »
Offline daisizhou
  • Country: cn
« Reply #11 on: June 03, 2024, 08:03:12 pm »
Carbon composite inductors or carbon core inductors
OK .My wrong perception
« Last Edit: June 03, 2024, 09:52:45 pm by daisizhou »
Offline wraper
  • Country: lv
« Reply #12 on: June 03, 2024, 08:44:55 pm »
Makes no sense, who the hell would put carbon core into inductor. Not to say supposed 10uH inductance won't be possible with non ferromagnetic core.
Offline floobydust
« Reply #13 on: June 03, 2024, 09:18:03 pm »
OP, I recognize the components as Dale (Vishay) inductors, the IM series.
The following users thanked this post: wraper, Andy Watson, tooki
Online jmelson
« Reply #14 on: June 04, 2024, 01:59:30 am »
Those are inductors, for power supply filtering.
Jon
  • Country: no
« Reply #15 on: September 02, 2024, 04:27:09 pm »
Thank you very much for your help.
Yes, those are indeed inductors.
I ordered new ones, as well as tantalum capacitors for the power rails.
Unfortunately, this didn't solve the issue.
When I re-powered the device after fitting the new components, the "holy smoke" returned...
