Author Topic: SWR LA 12 Bass amp inop. Powers on, only humms  (Read 617 times)
Offline 2222Topic starter
« on: January 05, 2024, 12:19:16 am »
SWR model LA 12 60 watt bass amp powers up but only hums (suspiciously like 60Hz?). A friend gave it to me to, thinking I might be able to fix it.
One chassis attachment screw is missing, and others show marking that it has been opened up previously.
At first it almost started to amplify a test signal, then it started thumping the speaker several times per second. When I powered it off it let out a squeal that rose in pitch until it quickly faded. Insides have a faint burnt electronics odor.
I may have identified what looks like a dry solder joint at the (marked "+") leg of what is labeled BR1 (bridge rectifier?).
Photos to follow.
Re: SWR LA 12 Bass amp inop. Powers on, only humms
« Reply #1 on: January 05, 2024, 12:24:08 am »
Preamp photos
« Reply #2 on: January 05, 2024, 12:29:31 am »
Power amp photos
Detail of possible dry solder joint on BR1 "+" leg.
Offline p.larner
« Reply #3 on: January 05, 2024, 01:16:30 am »
maybe it doesent know the words to the songs?,couldnt resist that! lol.
« Reply #4 on: January 05, 2024, 01:19:28 am »
Good one! :-DD
