Recently thru a friend, got an offer for an agilent 34411A 6½ Digit bench meter, the seller claimed that its brand spanking new and only used for few times, and it was from an abandoned project in building a new electronic testing lab in a huge consumer product electronic factory last year.
The offered item includes the original box, complete with genuine agilent probes as stated in check list, documentation + software CD, original power cable and the calibration certificate from agilent factory, but the seller didn't mention the printed date of the certificate. Offered price is close to about 980 in US$ equivalent, while for new price this bugger is around US$ 2100.
I'm aware this is definitely gray (or even black) market type of deal
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
, assuming its working properly, is this price worth it ?
Btw the seller allows only physical inspection and brief test at his place, say I'm going to pull the trigger, any hints or helps how to check it if its working properly only in a very short time frame, say like in 30 minutes or 1 hour ?
Also is there any standard warranty seal from Agilent factory for this kind of equipment that I should aware of ?
TIA
